1996 Audi A4 BRAKES AND ABS LIGHT
ANDYP8
Brakes problem
1996 Audi A4 V8 Two Wheel Drive Manual
IVE HAD NEW BRAKE PADS PUT ON AND MY ABS LIGHT KEEPS COMING
Aug 23, 2009 at 12:56 AM
DUBTECH
  • 159 POSTS
Did the light start coming on after the brake job?
If so, make sure the wheel speed sensors did not get disturbed during the brake job.
If the sensors appear to be installed correctly, then you should have the ABS computer scanned for any fault codes.
If you can post the code(s) I can lead you in the right direction for a repair.
Aug 24, 2009 at 2:16 PM
