1996 Audi A4 A/C Contol head
1996 AUDI A4
JAMES BICKERSTAFF
Computer problem
1996 Audi A4 4 cyl Front Wheel Drive Automatic
How do I change out a A/C Control head on 96 Audi
A4 Part number is 8D0-820-043H-5WK
Nov 25, 2008 at 8:05 AM
  • 55,423 POSTS
Hi, begin by removing the lower gear shift cover, then remove the face plate, the control head is held in place by servral mounting screws, wires, lines, and posible cables. Once the old unit is out reinstall with new and recheck system. Note disconnect the battery before you starting.
Let me know if you run into problems
Nov 25, 2008 at 10:13 AM
