1995 Audi A4 engine oil mixing with the water.
1995 AUDI A4
158,000 MILES • 6 CYL • FWD • MANUAL
JACO30
hi, i need advice on my audi, the engine oil is mixing with the water.. the block was skimmed and the heads. the engine started mixing the oil and water and i then took the block and heads to the engineering for pressure testing. all came back that it was fine. i redonr the engine and i am still having the same problem, the vehicle doesnt have an oil cooler as i had that checked already. if any body can give me advise thanks
Sep 11, 2010 at 5:16 AM
ERNEST CLARK
  • 1,730 POSTS
I first need to know where the oil and water are mixing. Is this in the crank case or in the cooling system?
If it's in the crank case, you have a blown intake/head gasket. If it's in the cooling system, and you don't have a oil cooler, then that is transmission fluid, not oil mixing with the coolant.
This will happen when a crack develops inside the radiator (the radiator has a built-in tranny cooler as well).
You'll have to replace that.
Sep 21, 2010 at 3:32 AM
JACO30
the oil is mixing into the water and pusing the water out of the water bottle. the engine oil goes missing, i do understand the radiator can have an oil cooler but there is no pipes going to the radiator.
Sep 21, 2010 at 5:19 PM
ERNEST CLARK
  • 1,730 POSTS
The radiator wouldn't have both a tranny cooler and oil cooler. If your oil is getting into the coolant, then it's either a blown head gasket, intake gasket or cracked block or head. (Despite the previous pressure test, there's no other way)
A pressure test will find it.
Sep 22, 2010 at 9:01 AM
