Leaking diesel
93,000 MILES • 2.0L • 4 CYL • TURBO • FWD • MANUAL
DAN PERKS
Yesterday the car started getting louder in general and the ride got a bit rougher. Today, I pulled up and immediately smelt diesel, so I popped the bonnet to have a look. The left side over the car was covered in diesel but cannot determine exactly where it is coming from. Upon inspection, I noticed a joint (I do not now the part name) was cracked completely. Cannot get into a garage until Tuesday, but would like a heads up and any extra information possible.
Please find attached pictures
http://tinypic.com/r/6gh9bd/9
http://tinypic.com/r/2useecp/9
Many thanks,
Dan
Aug 13, 2016 at 3:50 AM
  • 31,937 POSTS
Wash the diesel away and run the engine you should see the leak straight away, may be a faulty hose fitting its a bit had to say looking at the picture, as for the broken fitting that looks like a broken engine mount bracket.
Aug 13, 2016 at 9:49 PM
DAN PERKS
Thank you very much for your response. In your professional opinion, would you say this is a timely/costly job?
Aug 14, 2016 at 12:56 AM
  • 31,937 POSTS
cannot say until the leak is identified, but normally these things are fairly minor, as for the broken mount, if that what it is, this may be a bit more expensive. get a quote first and compare a few work shops for pricing,
Aug 14, 2016 at 7:39 AM
