Where is the climate control computer located?
2011 CHEVROLET SILVERADO
225,000 MILES • 4.8L • V8 • 2WD • AUTOMATIC
KAM0110
The problem now is the compressor comes on for 20-30 seconds and shuts off. Then the cooling fans come on. They are supposed to run together but are not. When one shuts off the other comes on and vice versa. What could the problem be?!?! I'm at a loss. Fuses good. Relays good. Serpentine belt good. I wasted way too much money on valves and Freon at this point. When I had it diagnosed, they said blow motor and resistor. I replaced both of those and it has gone downhill since. Replaced July 6, 2021. Now blows straight hot air. And now, I have a compressor problem.
Jun 22, 2022 at 5:15 AM
This sounds like a compressor that is short cycling. So, this means we must start with checking the pressures of the high and low side.
Basically, we need to find out what these are before we do anything else.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
If we don't know what the pressure is, then we are just going to be guessing so let's start with this.
Then I am attaching a chart below that will help with finding an issue with the pressures.
Let me know if you have questions.
Thanks
Jun 23, 2022 at 1:54 AM
