Acts like it is out of gas
174,000 MILES • 4.6L • V8 • 4WD • AUTOMATIC
AMBER-MICHELE
Acts like it is not getting gas. I heard it could be the Anti-theft causing the problem. How do I fix this?
Nov 14, 2018 at 3:33 PM
  • 110,251 POSTS
Hi and thanks for using 2CarPros.com
If there is a problem with the security system, the light will flash or not turn off. If that is the case, first try a spare key to see if that helps.
If that is not what is happening, take a look through this link. It discusses causes of a crank/no start. Also, it shows how to check different things and repair them.
As you will see after reviewing the aforementioned link, there are several things that can cause a no start. What I suggest is this. First, check for fuel and spark to the engine. Here are links showing how that is done:
You will need a gauge. Most parts stores will lend or rent one to you. Here are the manufacturer's specs for fuel pump pressure.
ITEM .................... SPECIFICATION
Key on, engine off .................... 207-276 kPa (30-40 psi)
Engine running .................... 207-276 kPa (30-40 psi)
Let me know if I can help or if you have other questions. I can help guide you if needed. Once you complete these tests, let me know what you find.
Nov 15, 2018 at 12:01 PM
