Anti-theft mode
2010 VOLKSWAGEN JETTA
105,500 MILES • 2.5L • 5 CYL • 2WD • AUTOMATIC
CHAVA BAUTISTA
My car is on anti-theft mode.
Jul 14, 2019 at 3:19 AM
  • 55,433 POSTS
Can you try locking and unlocking the car using your remote? Here is a guide to help you reset the system:
https://www.2carpros.com/articles/how-to-reset-a-security-system
Jul 15, 2019 at 6:58 AM
F4I_GUY
  • 3,302 POSTS
Hello, I assume you mean the immobilizer warning light is active? if the car starts for a split second then stalls with the immobilizer light flashing, you will have to scan the vehicle first. Usually you will see a key fault which would indicate the key needs to be replaced and programmed to the vehicle.
Jul 31, 2019 at 6:14 AM
