I have a coolant leak from the passenger side of the engine coming from around the water pump. At first I thought it was the water inlet pipe so I replaced that and the o-rings on it, but it's still the same so is the water pump gasket bad? I only replaced the inlet pipe cause the coolant would pool up along the bottom of the pipe. Any ideas on what else could be going on here.
Apr 12, 2016 at 10:16 AM
