Anti-theft system?
124,000 MILES
ROBINMCNULTY
The anti-theft system on my car was set off when I was trying to start my vehicle with remote starting from the key fob. The weather where we live has plunged into 20+ below zero. I haven't had any problems up until now. There's a car with a lock symbol through it on the dashboard information and the car will not start or turn over. The lights and electrical work, the fob allows me to lock and unlock the doors etc. I have tried several methods suggested online, three 10 minutes reprograming the key, putting the key in the door and holding it in the opening position for 30 seconds, none of them have worked. Does anyone have any clue how to disengage or reset it?
Dec 23, 2022 at 12:03 AM
  • 55,721 POSTS
I would do a hard system reboot, which is done by removing the negative side of the battery, with the cable loose from the negative side of the battery, hold it to the positive terminal for 1 minute this will discharge the memory capacitors in the BCM and PCM allowing the system to reboot. Also, this guide may help as well:
https://www.2carpros.com/articles/how-to-reset-a-security-system
Let us know what happens and please upload pictures or videos of the problem.
Dec 23, 2022 at 6:29 AM
