Anti theft system
2000 LINCOLN LS
217,000 MILES • V8 • RWD • AUTOMATIC
KRISTAL TURNER
  • 6 POSTS
Needing to know if there is anyway to reset the anti theft system on my Lincoln ls myself? It will crank over but will not start . It has done this once before and had a friend reset it with his computer. I am not able to afford for him to do this again so that is why I am here now asking this question. I have the key as well as the button that came with the car. Please help if anyone knows of a way to reset this on your own.
Sep 20, 2016 at 1:40 AM
HMAC300
  • 48,601 POSTS
try another key if you have one not a new one. if that does not work look online for your owners manual.
Sep 20, 2016 at 2:50 AM
KRISTAL TURNER
  • 6 POSTS
I have another key but I had to have it made recently due to my purse being stolen. I did get my original key and button back about a month ago .
Sep 20, 2016 at 3:20 AM
KRISTAL TURNER
  • 6 POSTS
I have been using both keys off an on what ever key I grab out of my purse at the time and it has been starting and driving fine, until the other day . I had ran out of gas and when ever I got gas and tried to start it again it would crank but not start.
Sep 20, 2016 at 3:24 AM
RYAN L
  • 272 POSTS
Running out of gas is really tough on your fuel pump. It might have burnt out. When you turn your key to the second position (without starting it) can you hear anything coming from your fuel tank? There should be some sort of sound like the fuel pump is trying to work. Have a helper turn the key to the second position while you listen for the sound. If you cannot hear anything, this could mean your fuel pump is burnt out and needs to be replaced.
Sep 20, 2016 at 5:09 AM
KRISTAL TURNER
  • 6 POSTS
I am not sure if I hear anything or not. I will get a helper an listen for it. Thanks for your help.
Sep 20, 2016 at 5:12 AM
RYAN L
  • 272 POSTS
Thank you for using 2CarPros.com! Please let us know what happens. If you have any other questions about your vehicle post a new question using this link. https://www.2carpros.com/questions/new We are always here to help!
Sep 20, 2016 at 5:22 AM
KRISTAL TURNER
  • 6 POSTS
Thank you for you time.
Sep 20, 2016 at 5:24 AM
HMAC300
  • 48,601 POSTS
have a helper hit bottom of tank with either a rubber hammer or palm of hand sometimes that makes the pump work. for how long is anyone's guess but it may get you where you need to go.
Sep 20, 2016 at 6:32 AM
KRISTAL TURNER
  • 6 POSTS
I will try that. I am still trying to find a ride to where it is broke down at so not able to try anything yet.
Sep 20, 2016 at 6:35 AM
  • 55,433 POSTS
Please let us know what you find so it will help others.
Best, Ken
Sep 24, 2016 at 9:39 AM
