1984 Other AMC Models
LESTER61
  • 1984 AMC
  • 4 CYL
  • 4WD
  • 200,000 MILES
Just replaced starter selinoid, now I am not getting spark from distributor
Sunday, July 11th, 2010 AT 9:22 AM
HMAC300
  • 48,601 POSTS
You probably have it wired wrong is the reason. Recheck everything again
Thursday, August 19th, 2010 AT 7:20 PM
REMIXEN
What is wrong plz explain.
Friday, August 20th, 2010 AT 6:18 AM
HMAC300
  • 48,601 POSTS
If you just replaced the starter and it doesn't run, then you may have put the wires in the wronng place on the solenoid. There should be "s" and an "i" terminal on the solenoid. The one side is for the stater to engage and hte other soots 12 volts to the coil to start the car. You I terminqaql is probabl not connected to anything. I do not know what color wire yyou need as you haven't identified what model car you have.
Friday, August 20th, 2010 AT 11:50 AM
