AM2 fuse blows when put in gear and shuts off
1993 TOYOTA CAMRY
150,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
VALRAY46
AM2 fuse blows every time when I put it in gear. Can anyone help?
Jul 17, 2018 at 3:29 PM
  • CERTIFIED EXPERT
  • 53,872 POSTS
That fuses feeds the ignition switch which I traced down to the Shift Lock ECU is the only thing that can be causing it. It is located in the center console check it for water damage.
Check out the diagrams (below). Please let us know what you find.
Cheers, Ken
Jul 18, 2018 at 6:46 PM
