Will not run after replacing Alternator/Water pump belt
179,849 MILES • 1.3L • 4 CYL • AUTOMATIC
HUGHESONE
I had to change both belts on car. After changing the belts it will turn over but will not run . What do I do bout this?
Dec 15, 2016 at 6:47 AM
STEVE W.
  • 15,418 POSTS
Follow the belts around and look for a connector that was knocked off/loose or wiring damage. It is easy to hit one when you are trying to route the belt and not even notice it.
Dec 15, 2016 at 7:12 AM
HUGHESONE
There were no connectors were found loose. Any more ideas on this matter?
Dec 15, 2016 at 9:45 AM
STEVE W.
  • 15,418 POSTS
You changed only the two accessory drive belts correct and then it would not start? The only thing I can think of is either a wire broke or a connector failed. Not much else on that area of the engine that can cause a problem. There are a couple grounds that control things like the fuel pump and the main relay that run in the area. When you turn the key "on" do you hear the fuel pump run at all? If not that would suggest that the ground had failed.
Or it could be some real odd coincidence that something else failed.
Maybe a run through the fuse panel would show a blown fuse.
Dec 15, 2016 at 10:28 AM
HUGHESONE
Ok went through and checked all fuses and connectors. Found nothing out of place or looses
Any other thoughts?
Dec 16, 2016 at 10:03 AM
STEVE W.
  • 15,418 POSTS
Check to see if the fuel pump is turning on and that you have pressure.
Also you could put a spark tester on each wire and see if you have spark.
Beyond that the only thing I can think of is something failed just at the wrong time. Because that car isn't sold in the US with that engine (we got the 1.8) it's a bit more difficult to diagnose. It is up to you on how far you want to go.
Dec 16, 2016 at 11:40 AM
