If I disconnect the battery cable for a while; while the engine is running the engine won't stop indicating that the alternator is working, but when I test the battery voltage while engine is running the battery voltage is exactly 12 volts indicating that the alternator is not working. However if I disconnect the battery cable and test the alternator output it indicates 14 volts. What could be the possible problem?
Sep 21, 2020 at 4:56 PM
