Alternator overcharging?
2003 FORD F-150
198,000 MILES • 4.3L • 6 CYL • 2WD • MANUAL
TEMICA LITTLETON
Truck wonk crank. I've replaced the battery, alternator, and the relay but I'm still getting a 14 on alternator with voltage regular. Can this be that the alternator isn't ground properly.
Aug 26, 2023 at 8:29 AM
  • CERTIFIED EXPERT
  • 53,872 POSTS
I will need more information to help you, you said the engine won't crank over? so, the engine is not running, correct? Where are you testing that you get 14 volts without the engine running?
Aug 26, 2023 at 7:19 PM
