1996 Mercury Sable Intermittent Blower
1996 ALL OTHER MAKES ALL OTHER MODELS
AVERYR
This strange problem occurred about three months ago. The blower fan (A/C Defrosters etc) only works when it wants to. Once it turns on, it stays on and doesn’t turn off by itself.
The switch for the fan is incorporated into the radio panel. It is “pressed” and not turned. (I am told that not all Sables have this set up).
When I start the car it’s the luck of the dice whether or not the A/C will work. Sometimes the blower starts upon pressing the switch and at other times it will remain off for five, ten, twenty minutes or more. Once it starts it stays on without a problem. I suspect there is a relay or some other device that’s failing. Any thoughts?
I have plenty of coolant, the A/C works well, but without a fan it’s useless. My electrical system is fine. Recently replaced the battery and alternator (this problem began for that repair).
Any help is appreciated.
PS: The car has 110K miles on it.
Jun 10, 2006 at 5:03 AM
EPERRY
  • 21 POSTS
have your blower fan checked or check it yourself by running a wire from your ground of the battery to the gound on the blower motor & take a wire from your pos on your battery and put it on the others on the blower one at a time not all together if it don't run then the blower is gone.
Jul 20, 2006 at 10:22 PM
Suggested Repair
Direct-test the blower motor by applying battery positive and ground to its terminals one at a time. If the motor does not run, replace the blower motor.
Conversation Summary
The owner of a 1996 Mercury Sable says the climate-control blower starts only intermittently, then stays on once it runs. The fan switch is a push control in the radio panel, and the owner suspects a relay. An expert recommends applying battery power and ground directly to the blower motor and replacing the motor if it does not run.
