1993 Suzuki Swift No Spark
1993 ALL OTHER MAKES ALL OTHER MODELS
AUDIE BUCKNER
  • 9 POSTS
help!93 suzuki swift has no spark from coil or plug wires-12volts to coil terminals-12 volts to igniter module under coil on one wire-.66 volts to dist. key on at both wires-when cranking engine the dist. has .86 volts=less than one volt!-traced dist. wires to computer connecter-same volts there. engine has been sw :?: itched and brought to me with no spark.tried several parts -no volts to dist. is where problem is i think--help!
Apr 25, 2006 at 4:42 AM
LOSONE
  • 1,616 POSTS
Give me exactly waht it will or won't do. I feel that it may need an ignition module but be more specific about the symptons without voltage readings.
Apr 25, 2006 at 4:47 AM
AUDIE BUCKNER
  • 9 POSTS
no spark-fuel pump runs a few seconds-dash lights work normal-no spark when cranking-tried a new module under coil-still no spark- help and thank you for the quick reply!
Apr 25, 2006 at 4:52 AM
LOSONE
  • 1,616 POSTS
Those 1.3 have a high timing belt failure. Pull the distributer cap turn the engine so the timing mark is on TDC and insure the rotor is pointing to #1 cyl. Good luck
Apr 25, 2006 at 5:00 AM
AUDIE BUCKNER
  • 9 POSTS
hello! dist. rotor movimg when cranking -think timing belt is normal-no spark when cranking-shouldn't there be 12 volts to dist.? tried another computer -numbers different-no spark.help? thanks!
Apr 25, 2006 at 5:40 AM
LOSONE
  • 1,616 POSTS
There should be 12V to the distributer. Check all fuses especially to the ECM
Apr 25, 2006 at 6:35 AM
AUDIE BUCKNER
  • 9 POSTS
all fuses good under hood and dash.don't know where dist. gets voltage from.i know the 2 dist. wires go directly to computer terminals.i have old engine and have traced all wires.i need wiring schematics to maybe see where power comes from .i have many manuals;but none precise for swifts.thanks!help?
Apr 25, 2006 at 7:21 AM
LOSONE
  • 1,616 POSTS
The GM geo metro of that year is the same vehicle and the wiring the ame. The 12V comes from the ignition switch.
Apr 25, 2006 at 7:55 AM
AUDIE BUCKNER
  • 9 POSTS
gonna give up for today;and try to look at a schematic .thank you for your time today!
Apr 25, 2006 at 10:22 AM
AUDIE BUCKNER
  • 9 POSTS
hi! got to do a little on car today-looked in factory shop manual for a couple hours. dist. voltage with key on should be .04 to.08 volts-and it is.got resisistances for several parts and test procedures. hope to find something defective. also checked air gap in dist.-it had no gap at all! set to .008+ - switched two relays in fuse block.got more to check tomorrow. thanks!
Apr 26, 2006 at 2:25 PM
AUDIE BUCKNER
  • 9 POSTS
help!still no spark-got code 41 -no dist. signal-car has same voltage at 2 dist. wires and 2 terminals on computer-resistances for pickup,coil all normal.does anyone think it is computer? help! thanks!
Apr 29, 2006 at 8:29 AM
LOSONE
  • 1,616 POSTS
As much as I hate to say it, it might be the little processor.
Apr 30, 2006 at 6:52 AM
AUDIE BUCKNER
  • 9 POSTS
WHAT AND WHERE LITTLE PROCESSOR?THANK YOU FOR ALL YOUR REPLYS! THE COMPUTER IS OVER 1300$ RETAIL.
Apr 30, 2006 at 2:13 PM
AUDIE BUCKNER
  • 9 POSTS
I TRIED ANOTHER USED COMPUTER.SAME RESULTS NO SPARK.
Apr 30, 2006 at 2:16 PM
JIMB355
  • 5 POSTS
u said the #'s on the ecu were different than the one on your original ecu? there are several ecu's for these vehicals! u need the correct one!! my mother in-law has a sidekick and i had the same problems as you! i've got on line and had the same luck as you are! i even found a way to test the ignitor with a battery and a volt meter! in the end after weeks of searching i found the correct ecu pluged it in and she fired up and ran!!!!
Oct 25, 2006 at 1:07 PM
Suggested Repair
Install the correct ECM/ECU for this 1993 Suzuki Swift 1.3; several ECUs exist and a used unit with different part numbers will not restore spark. Code 41 means no distributor signal. Also confirm pickup air gap (about 0.008 in), coil and pickup resistance, fuses, and ignition-switch power before replacing other parts.
Conversation Summary
A 1993 Suzuki Swift 1.3 had no spark while cranking, though the fuel pump primed and dash lights worked. A new igniter, good fuses, normal coil and pickup resistance, and a moving distributor rotor did not restore spark. Key-on distributor voltage matched the manual (about 0.04-0.08V), not 12V. Code 41 indicated no distributor signal. A used computer with different numbers also failed. An expert suspected the processor, and another owner reported the same no-spark problem was fixed only after installing the correct ECU.
