The fan shroud channels are to run through the radiator and cools the radiator, with the engine cool, start the engine with the radiator cap off and watch the radiator for coolant flow, does it happen when you are just running it or when under load? The radiator could be clogged. Flush the system to get clean it out. You should get a shroud on the engine.
SPONSORED LINKS
Sunday, April 29th, 2007 AT 9:45 AM
