overheating
2001 ALL OTHER MAKES ALL OTHER MODELS
45,000 MILES • 4 CYL • AWD • AUTOMATIC
ALERO925
Constantly overheating
repaired hoses, thermo stat, coolant reservoir
now they are saying it might be electrical
Jul 19, 2009 at 4:45 PM
SQM
  • 6,383 POSTS
The engine can overheat due to a number of reasons.
It could be due to having low coolant, a stuck closed thermostat, bad radiator, faulty water pump, contaminated coolant or having blockage in the cooling system. It can also overheat due to inoperative cooling fans.
https://www.2carpros.com/articles/symptoms-of-an-overheating-engine
Do you know if the cooling fans are operational?
Inoperative cooling fan will lead to overheated engine. The cooling fans might not work due to a bad fan relay. It can also be due to bad wiring or malfunctioning fan motor.
Checking the relay should be the first step.
Keep in mind that a faulty temperature sensor will also prevent the fan from turning on.
https://www.2carpros.com/articles/how-a-coolant-temperature-sensor-works
Nov 18, 2021 at 1:03 AM
