2000 Grand Am fan only blows in 3rd and 4th position
2000 ALL OTHER MAKES ALL OTHER MODELS
MEATNPOTADAZ
The fan on my 2000 Grand Am GT only blows in the 3rd and 4th positions (the two highest), and doesn't blow at all in the 1st and 2nd. Just wanted to know if this is the blower relay, and where I can find it under the dash to replace it.
Feb 10, 2007 at 9:45 AM
KNIGHTRIDERKITT2000
  • 93 POSTS
blower motor resistor,and it should be mounted near or on your blower motor housing,
https://images.2carpros.com/forum/automotive_pictures/13857_getimage_2.jpg
this is what you are looking for
Feb 11, 2007 at 3:33 AM
M1GARAND
  • 12 POSTS
Just fixed the same problem on my daughter's 2001 Sunfire. Her blower was falling apart and she had no heat because the fan jammed against the housing. I found that setting 1 and 2 did not work either, due to the resistor being corroded. The fan was easy to get in and out, but the resistor was a bitch because it is nestled close to the firewall. I had to cut away some of the soundproofing/ insulation to get at the back mounting screw. Well worth it though, the blower works like never before.
Feb 12, 2007 at 1:49 PM
