Check engine light on and codes 171, 174 and 401
1996 ALL OTHER MAKES ALL OTHER MODELS
PIGHUNTER819
I have a 96 F-150. 4.9L inline six engine. My check engine light came on. Trouble codes read 171(System too lean bank 1) 174 (System too lean bank 2) and 401 (EGR flow insufficient). Where is a good place to start? Truck seems to run sluggish and sometimes after stopping from high speed on the highway it will stall. Any help will be great.
Feb 24, 2007 at 4:40 PM
  • CERTIFIED EXPERT
Good evening,
The 171,174 are lean codes.
You need to test for vacuum leaks as that is common. Make sure the PCV valve is also working.
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
Also, check the fuel pressure. Low fuel pressure will also cause this code.
The 401 is for the DPFE sensor. Very common failure. When you replace it, make sure the lines are replaced as well.
Mar 25, 2020 at 4:00 PM
