1993 Pontiac Grand Prix Rear Swing
1993 ALL OTHER MAKES ALL OTHER MODELS
ROBCET1
  • 13 POSTS
I have a 1993 Grand Prix. 118000 Miles on it. I bought this car used. Really need some help to figure out my problem. When driving the car, the rear end swings to the left, and will swing back to the right making this car very difficult to drive. Have had the car for about 7 months now. It seems to only be doing it when it rains or snows. On dry pavement it seems fine Any ideas? Thanks
Jan 21, 2007 at 10:44 AM
SERVICE WRITER
  • 9,123 POSTS
That sounds really weird and unsafe. There are a lot of reasons for a pull, the most glaring is something loose in the suspension or wheels.
Does the car set off kilt at all?
Do you hear any noises going over bumps?
Looking straight at the car from the front and then from the rear, do the wheel look tilted in or out at all?
These had rear disc brake problems with the calipers freezing up and also a transverse leaf spring in back that would eventually crack or break.
Get this looked at before an accident happens.
Jan 21, 2007 at 10:59 AM
ROBCET1
  • 13 POSTS
It does look a little like the rear Driver tire goes inward just a tad. I also noticed that my tire was completely bald and showing steel around the tire not on the outside facing, but the inside facing. Could this be it? Ive had bald tires before to where the steel comes out, but on the outside facing. Never have I seen it on the inside. Looked at the Passenger back tire and same thing. thanks
Jan 21, 2007 at 12:05 PM
SERVICE WRITER
  • 9,123 POSTS
That's a symptom of a bigger problem. That has to get taken care of. Setting that aside, you need to have the rear suspension looked at. There is something bent or loose I think. Comes back to my earlier statement. There is a suspension problem that is causing a toe-in condition. One wheel wants it to go left and then the other wheel wants it to go right is what you are feeling, and the rest of the time the wheels are dragging on the inside edge.
Jan 21, 2007 at 12:19 PM
ROBCET1
  • 13 POSTS
I'll have it looked at this week. Thanks, appreciate it.
Jan 21, 2007 at 12:25 PM
ROBCET1
  • 13 POSTS
I think I figured out the problem on my 93 grand prix. Had a friend look at it. 5 Lugs and 5 Studs. Im missing 2 lugs and 2 studs on the rear passenger side. Missing 1 lug and 1 stud on the driver side with one lug also stripped. Sound like the problem? Would that cause this? Thanks again for your help. Appreciate it Service Writer
Jan 24, 2007 at 7:12 AM
SERVICE WRITER
  • 9,123 POSTS
I don't think so. Was the wheel actually loose? If so, then I'd buy that. Wheel studs and nuts wear out. They get their life shortened everytime they go on and come off. If the wheel was loose the movement could help snap them. The thing that makes seem less logical is the problem isn't happening on dry straight roads. Have you got the car off the ground yet? If you can get in the rear suspension area and take a few pics, we might be able to see something of value. I still think there is a bent or loose suspension problem at this point. Which style rear suspension do you have?- The big difference that will be most obviuos is the coil spring or transverse spring.
https://images.2carpros.com/forum/automotive_pictures/30961_93gpcoil_1.jpg
https://images.2carpros.com/forum/automotive_pictures/30961_93gptrans_1.jpg
Jan 24, 2007 at 9:35 AM
ROBCET1
  • 13 POSTS
Wheel was loose. Going to take it in to a mechanic Friday have susp looked at. Will post my results. Thanks.
Jan 24, 2007 at 11:40 AM
SERVICE WRITER
  • 9,123 POSTS
Son of a gun!!! I'm surprized. Mostly at when you felt the problem. Curiousity has got me on this. That is probably the reason then!
Jan 24, 2007 at 11:49 AM
ROBCET1
  • 13 POSTS
Sorry man, been away for awhile. I figured out that the problem was caused by a broken trailing arm.
Jun 8, 2007 at 3:50 AM
Suggested Repair
Replace the broken rear trailing arm, replace missing or stripped wheel studs and lug nuts, and have the rear suspension and alignment inspected. Replace tires worn to the cords on the inner edges.
Conversation Summary
The owner of a 1993 Pontiac Grand Prix said the rear end swung left and right in rain or snow and that the rear tires were worn to the steel on their inner edges. The expert suspected a bent or loose rear suspension causing toe-in, and also mentioned frozen rear brake calipers or a cracked transverse leaf spring. Missing studs, a stripped lug, and a loose wheel were found. The owner later reported that a broken trailing arm caused the problem.
