1992 F150 Surges/Stumbles when warm
1992 ALL OTHER MAKES ALL OTHER MODELS
JLCLJAYNE
I have a 1992 F150 with the 5.8. It runs good when cold, idling and wide open throttle. It surges or misses when warm and at a constant speed. You can feel a slight miss or hesitation when at cruising speed. The truck is new to me but so far, these are the the things I have done or replaced.
New plugs, wires, cap, rotors. New IAC, cleaned EGR and new TPS. Cleaned throttle body, replaced air and crankcase filters, new pcv valve. I have checked timing, checked vacuum hoses and tried to find any intake air leaks but have not found any.
I haven't checked fuel pressure or tested anything with a vacuum gauge as I do not own any...yet.
Please help! What might be causing this irritating problem?
Apr 19, 2007 at 6:10 AM
MERLIN2021
  • 17,250 POSTS
After changing all this is the engine light on? Does this truck have sefi or carb?
Apr 19, 2007 at 7:19 AM
JLCLJAYNE
There has never been a check engine code. None stored either.
Apr 19, 2007 at 8:27 AM
MERLIN2021
  • 17,250 POSTS
Fuel injected or carb?
Apr 19, 2007 at 8:30 AM
JLCLJAYNE
Fuel injected. Installed new EGR and EVR sensor but still have the problem. I even tried a new EGR vacuum solenoid but problem still exists.
Truck runs great when I disconnect the EGR.
Apr 24, 2007 at 3:39 AM
