How do I tell if my clutch is slipping. I only have to push pedel in a bit to get her to disingage. I have 4.0 L with 5 speed.
Wednesday, March 21st, 2007 AT 3:56 AM
MIKE H R
MECHANIC
Check the adjustments on the pedal, it could be that the linkage is loose and have to be adjusted. The pressure plate might be going bad. When driving put the transmission in the next higher gear and see if it slips under load.
