Started around 2016 but could have been like this from day 1 as I do not travel long distance that often, intermittent but occurs only after driving continuously for over 1 hour. You can hear the blower is still working but no air flow from any vents even when changing modes, auto, manual, dual, hot, cold, fresh air, recirculate, A/C. Happens in winter or summer.
In summer the interior of the vehicle starts to warm up because there is no air flow. In winter the windows start to fog and I have to pull off the road.
In all circumstances, turning off the car for at least 20-30 minutes will reset it. Dealership even tried static discharge and disconnecting battery but that didn't work. And I knew it wouldn't (I do have an electronic troubleshooting background and know intermittent problems are the hardest to stop).
Of course the dealership got no where with it as there is only a 15 minute window to try anything once the car is off.
Possible clues: since day 1, the air flow from front vents only was never that powerful, I've never had to lower blower speed or increase target temperature because it got too cool inside. Yet the temperature at the vent was below 45 degrees F.
Since day 1, in winter, the air flow to feet was never that powerful. During long trips my feet would freeze even with manual full floor venting!
I thought these low air flows were normal bad engineering traits of the car but recently discovered from sitting in other Optima's my car was not the norm. This I now believe is a major clue to the vent problem.
Why only after an hour of run time total flow blockage occurs is where your expertise comes in.
Aug 1, 2019 at 7:31 AM
