I hit a curb on the passenger side of the car going about 10-15 mph. Afterwards the alignment has been off pulling to the right (passenger side) I have replaced the struts and upper control arms both sides, the outer tie rod on the passenger side and steering knuckle on driver side. But there was no change plus or minus in the pulling. When I let go of the steering wheel it will almost make a 90 degree turn. I cannot see any places that are visible bent or out of whack. I have been told it could be the rack an pinion or the steering knuckle on the passenger side, someone also suggested that it could be the bushings on the lower control arms. Please let me know which I should look at first?
Dec 23, 2019 at 8:45 AM
