1990 Alfa Romeo Spider Cylinder Sleeve seals (o rings?)
63,000 MILES • 4 CYL • 2WD • MANUAL
MJONO53
How do I remove the cylinder sleeves in order to replace the seals?
Thank you
Jun 10, 2009 at 12:05 PM
DR LOOT
  • 2,311 POSTS
you will either have to purchase or rent a special tool called a sleeve puller, if you have the engine out of the car you can turn it over, and knock out with a 2 x 4 or a piece of hardware and a hammer
Aug 26, 2009 at 7:55 AM
