Alceration problem
6,000 MILES • 5.2L • V8 • RWD
ERNIE1987
i have a 1987 Chrysler Fifth Avenue 318 904 transmission. I replaced the fuel filter and pump, the timing chain, water pump. I had a new battery, new starter, and a rebuilt transmission. When I'm stopped and I go to give it gas it loses power to the acceleration, then after a quick second it picks up and it drives fine. It only does it once in a while or alot sometimes only when I'm at a complete stop.
Mar 4, 2016 at 10:00 AM
CATAFINA
  • 167 POSTS
Check the throttle position sensor, then get back to us for more.
Mar 4, 2016 at 12:58 PM
HMAC300
  • 48,601 POSTS
Try cleaning throttle plate with choke cleaner on both sides and iac hole. If it has a carburetor have the carburetor checked, it may need an overhaul due to alcohol in today's fuel.
Mar 4, 2016 at 11:48 PM
