Air keep blowing out from engine main filter hole
120,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
ZACH134
This didn't happened before , I left my car at home for 1 week and after I came back from holiday , I try to start my car for a warn up , after the engine started I open the main oil filter cap , I realize there suddenly air blowing out from it , I had send my car to some workshop for some valve check , all valve and air hose are in good condition , what happens to my car ?
Jul 10, 2014 at 12:43 PM
  • 110,248 POSTS
Air is produced in the combustion chamber via compression bypassing the cylinder rings. ALL cars do this. There is a PCV valve that is to recirculate the crankcase emissions back into the engine. First, don't be too worried about this happening. They all do it to some degree. However, I do recommend that you checked the PCV system and make sure it is producing a vacuum to help draw the crankcase emissions out of the engine.
Jul 10, 2014 at 1:02 PM
