Welcome to 2CarPros.
The first thing that needs check is what the pressures are in the system. It could be too high or too low. Here is a link that explains how to evacuate and recharge a system. I am including the link because it shows the manifold gauges that are needed to check pressures. Often times, a parts store will lend or rent one to you.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
When checking the pressures, note the outside temperature and let me know both.
Here is a general link that you may find helpful too:
Let me know the results.
Jun 30, 2019 at 12:22 PM
