A/C not blowing very cold
116,500 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
LSEDANO22
AC was blowing warm. Had it services, no leaks. New condenser fan, expansion vale, compressor and dryer receiver replaced system was flushed. It now blows at about 56-60 degrees. What can it be that it is not getting to the 50-40 degree level?
Thank you for any information. i can get
Aug 12, 2019 at 6:17 AM
Good afternoon,
What is the outside temperature?
What are the high and low side pressures for the system while running?
Aug 12, 2019 at 6:44 AM
LSEDANO22
92 temperature outside. I do not no the high low as I did not perform the service.
Aug 12, 2019 at 6:48 AM
At 92 degrees, 54 degrees duct temperature is normal.
Beyond that, I need the pressures.
Aug 12, 2019 at 6:51 AM
LSEDANO22
Okay, I will get that information. I can tell you that prior to the compressor being replaced. The low was reading extremely low and high was extremely high.
Aug 12, 2019 at 6:55 AM
Okay, let me know the readings when you can.
Aug 12, 2019 at 7:06 AM
