A/C low port location needed
2010 RENAULT KANGOO
60,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
GEORGE CHERRY
  • 5 POSTS
Where is A/C low port on my car listed above?
Jun 30, 2018 at 9:01 PM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
I am trying to find a picture reference for you, but in the meantime in you HVAC system the metal lines in the engine compartment will have a Schrader valve service port. The larger in diameter size line is the low side. That is the side of system to add refrigerant and usually has a Blue plastic protective cap. If you are looking to add refrigerant as a DIY the cans sold that you buy can only be attached to the low side because the Schrader valve bungs are different in size between the High and Low side for that reason. I have attached a tutorial for you and hope this helps. I will continue to look for a picture if it helps as well.
Danny-
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
Jul 1, 2018 at 5:47 PM
GEORGE CHERRY
  • 5 POSTS
Renault Kangoo 2010 as only one valve.
Jul 1, 2018 at 5:56 PM
DANNY L
  • 5,648 POSTS
Hello again.
Did you purchase a DIY refrigerant recharge kit and try to install?
Danny-
Jul 1, 2018 at 7:16 PM
GEORGE CHERRY
  • 5 POSTS
Yes, and it gone in okay your only one valve
working okay. Thank you Danny.
Jul 1, 2018 at 7:37 PM
DANNY L
  • 5,648 POSTS
Hi again.
You are welcome and thanks for using 2CarPros.com. Danny-
Jul 1, 2018 at 7:40 PM
