Yes, it ties into the oil pressure switch just as an override if and when the fuel pump relay will not work for some reason after cranking the engine over enough that the oil pressure builds to 4 psi, the fuel pump will run.
But that is not why the fuel pump relay is clicking off and on.
First of all, are you sure you have twelve volts at the battery?
If so, remove the fuel pump relay and make sure that twelve volts is reaching the relay socket. One of those spots in the socket will only be hot when the key is first turned to run for about two seconds, that is the one you want to test but while you are there go ahead and confirm an additional spot has twelve volts with key on run, that should be coming from the fuse #8. Then if all okay, check the ground. If it is marked it will be the C pin or black/white wire. With an ohmmeter to that C pin and a metal ground or the negative battery post it should read under 5 ohms.
If all okay, try a new relay.
SPONSORED LINKS
Friday, February 2nd, 2018 AT 8:14 AM
