After market products
2011 MERCEDES BENZ ML350
135,000 MILES • 3.2L • V6 • TURBO • 4WD • AUTOMATIC
JACOB DERKSEN
If I use after market parts can the computer be reset?
Apr 5, 2019 at 4:15 AM
  • 110,236 POSTS
Welcome to 2CarPros.
If the part is made specifically for your vehicle, you should be fine. However, I do recommend caution when purchasing things online. Make sure it is a reputable seller before making purchases.
Let me know if I can be of any help.
Apr 5, 2019 at 1:45 PM
JACOB DERKSEN
Can I use after market oxygen sensors on my 2011 ml350 v6bluetec diesel?
Apr 5, 2019 at 4:09 PM
  • 110,236 POSTS
Welcome back:
I have to start by saying, there usually isn't anything as good as the original equipment, but in reality, they make the sensors to take the place of OEM parts. I'm sure they have to meet the same specifications, otherwise no one would want them. On the other hand, I wouldn't recommend getting the cheapest thing available if you plan to keep the vehicle. If you find an aftermarket part that was made by a reputable manufacturer, it should be fine.
With that, I don't see why it should be a problem.
Let me know if you have questions or run into trouble.
Apr 6, 2019 at 10:46 AM
