advisories on potential purchase of vehicle
2004 MITSUBISHI SHOGUN
115,000 MILES • 2.4L • 4WD • MANUAL
ADAMMAYES44
I am thinking of buying this vehicle but it has these advisories below. I just wondered (roughly) how much it would cost to fix these? the vehicle is advertised for £1500
Front Anti-roll bar has slight play in a pin/bush (2.4.G.2).
Offside Front Track rod end ball joint has slight play (2.2.B.1f).
Rear Brake pad(s) wearing thin (3.5.1g).
Oil leak ().
Thank you so much if you can help.
Oct 4, 2017 at 6:17 AM
STEVE W.
  • 15,348 POSTS
Anti-roll bar (aka sway bar) end links. About $30.00 each, takes about half an hour to change both if they are not rusted in.
Track-rod-end (tie rod end). About $35.00 and takes about fifteen minutes to replace and add in half an hour to reset the tow.
Rear brakes. Cost will depend on if it also needs rotors and parking brake shoes replaced as well. From $100.00 to $500.00 depending on what is actually needed. No way to tell without having it apart and checking the parts.
Oil Leak.This will depend on what is actually leaking. Something like the valve covers might be $200.00, but if it is a rear main seal or oil pan the price goes way up quick.
Oct 4, 2017 at 6:59 AM
ADAMMAYES44
Amazing reply thank you so much extremely helpful.
Oct 5, 2017 at 2:31 AM
STEVE W.
  • 15,348 POSTS
You are welcome. Thank you for using 2CarPros.com.
Oct 5, 2017 at 6:08 AM
