Adding a manual switch for coolant fan, is there a way i could wire in another relay for this to work without throwing a code?
136,705 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
JLBEREL3
My coolant fan will only come on when it gets hot, like normal. But i wish to add a manual switch that i could turn on when i turn on the A/C so it might cool at idle. Is there a way i could wire in another relay for this to work without throwing a code? Thanks in advance!
Jul 11, 2023 at 1:38 PM
STEVE W.
  • 15,409 POSTS
The fan should already turn on when you turn on the A/C. However, that fan doesn't run constantly like they used to, instead they monitor the HVAC system using the PCM and its sensors as well as the pressures and A/C operation to cycle the fan on and off as it is determined to be needed. That is done to improve fuel economy as the pans do draw quite a bit of power. As for adding a switch, you could, but it won't change the operation of the A/C and in reality, may make it worse in modern designs. Also, to answer the question, yes it would set a code, most likely a thermostat cover as the PCM would know it isn't cycling the fan, but the coolant temperature is going down. Under normal conditions the low-speed relay will be the one that turns on first and then cycles off.
If the A/C doesn't seem to operate very well, you might need to service it.
Jul 12, 2023 at 9:33 PM
