2004 Acura TSX how to change a rear rotor
2004 ACURA TSX
69,875 MILES • 4 CYL • FWD • AUTOMATIC
NEWXGRRL
How do I change a rear rotor? I have already removed the caliper. I was told by honda that the hub did not need to come off to replace the cracked rotor but i am finding that it is impossible. can you please help me.
Aug 8, 2008 at 3:10 AM
KHLOW2008
  • 41,814 POSTS
Hi newxgrrl,
Have you removed the caliper mount?
The rotor is sticking tightly onto the hub and need to be released by banging with a hammer or using 2 pcs of m8 bolts to tighten into the 2 threaded holes on the rotor hub to remove the rotor.
Aug 20, 2008 at 2:12 AM
503TSX
should come off with some persuasion.
If you use the M8 bolts (they should just fit in the threaded holes) from my experience, make sure you tighten them evenly so the rotor slides off the hub evenly.
Sep 3, 2008 at 7:32 PM
