ENGINE TAPPING/KNOCKING NOISE, BAD VALVES?
ACURA TL
NAIEFELYEMENI
HI, i have a 96 acura tl 2.5 with 135,000 miles on it. I have a couple of questions.it's been making a ticking noise from the top of the motor since i bought it 6 weeks ago, but it was raelly small. Now since i replaced the spark plugs and it got a little colder i can hear it even more and it's a little louder.when i drive it enough,more than i expect for it to warm up then the ticking nois goes down? I'm thinking it's the valve(s) or oil to thick? I did put some sea fome into the engine ( 8 ounces) thinking it will eliminate the tapping noise bycleaning them from dirt or buildup? I have driven on it for about two weeks with the sea fome still in there! should i get it out or it's fine until i change my oil? i'm thinking the gap on the spark plugs are off maybe? or the wires are no good? how can i test out the wires if there good or not? pleasehelp me out! thanks!
Sep 13, 2007 at 6:30 PM
BRUCE HUNT
  • CERTIFIED EXPERT
  • 3,754 POSTS
First off I would get the oil changed and get out the seafoam. Then I might have a mechanic check the valve lash on the vehicle.
Sep 15, 2007 at 6:06 PM
