2003 Acura TL Transmission Problem
2003 ACURA TL
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
DZMOULOUDIAMCO
I have a 2003 Acura TL-S the car runs great with a perfect engine
Last april i took the car to Acura for servicing and i was told that there was a recall on transmission, something has to to with the 2nd gear and they put some kind of inject on it.
Anyway, last night while i was trying to park i did a reverse and than a D5 and the car wont move, it did eventually move, but it took its time, when ever i turned the car on and off, the transmission works perfectly.
In other words, when i start the car , the car works perfectly, but if i drive it for a mile or two and try to park, do a reverse and a d5, i start giving me problems other than that no problems.
NB: note that , if i turn the car off and on, the issue is gone
Any help would be greatly appreciated.
Sep 26, 2010 at 1:01 PM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
Hi DZMOULOUDIAMCO,
Get a scan done and see if you come up with any trouble codes.
Seems the control system is malfucntioning. Restarting would reset the control system, at least temporarily.
Sep 27, 2010 at 2:23 PM
