2002 Acura TL 2002 Acura TL-S Trunk wont latch
2002 ACURA TL
101,000 MILES • 6 CYL • FWD • AUTOMATIC
PETRORON
Is there a simple fix for the keyless entry for the trunk, it seems to be stuck in the open position, the closest dealer is a hour or so away,and was hoping this may be a simple problem, with a simple solution?
May 27, 2008 at 3:41 PM
SOPHIAL
This is an easy fix but unfortunatley, Acura makes it so that you need factory parts. You need the locking mech in the lid: if you can still move the mech in the trunk; if not the mech in the lid may be working properly and the mech in the trunk is not. Not sure if Acura will sell them separate or if it is a "set". Take to a local shop since your dealer is so far and see if they can asses which is the faulty part.
May 29, 2008 at 5:14 AM
