I understand the basic principles of a floating caliper. The piston pushes against the pad which contacts the rotor. Simple! But how does the other break pad on the opposite side make contact with the rotor?How is it "pushed" in the opposite direction? What are the fluid dynamics that cause the caliper to move in the opposite direction of the piston?
SPONSORED LINKS
Monday, April 6th, 2009 AT 1:47 PM
