1997 Acura TL clunking noise when shifting
1997 ACURA TL
67,000 MILES • 6 CYL • 2WD • AUTOMATIC
LSG2776
My 3.2 TL is making a clunking noise when shifting from 1st to 2nd gear. Almost like a u-joint is bad. Not even sure if this car has u-joints or not. It only happens when I give it alot of gas. If I takeoff slowly, it does not happen. Otherwise everything else is normal
THankyou
Aug 18, 2008 at 5:02 AM
KHLOW2008
  • 41,814 POSTS
Hi lsg2776,
There are no U-joints but there are CV joints.
The problem you are facing could be due to worn engine mounts, arm bushes, CV inner joints, worn transfer shafts.
Aug 18, 2008 at 9:29 AM
