1996 Acura TL Intermittent heat but fan and A/C work
1996 ACURA TL
120,000 MILES • 6 CYL • FWD • AUTOMATIC
THOROGRAPH
The heater on our Acura blows cold (unheated air) most of the time and only occassionally blows hot air regardless of how the temperature gauge set set, the fan setting or how the heat is directed (toward our feet, toward our face, etc.).
Oct 17, 2009 at 3:48 PM
  • CERTIFIED EXPERT
  • 110,176 POSTS
Is the cooling system full?
Oct 17, 2009 at 4:08 PM
THOROGRAPH
The cooling level is full and the radiator and thermostat were recently replaced (not due to the heater problem).
Oct 17, 2009 at 4:19 PM
  • CERTIFIED EXPERT
  • 110,176 POSTS
Okay, I need you to check someting. With the engine running, warm, and the heater on high, feel both heater core hoses at the firewall (under hood). Both should be hot.
Let me know what you find.
Oct 18, 2009 at 12:15 AM
