HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Acura
TL
Engine
Starter
1996 Acura TL Engines starts, but stops when starter stops
RCHAMP77
MEMBER
1996 ACURA TL
6 CYL
FWD
AUTOMATIC
221,000 MILES
The engine will crank, and will run while the starter and the key is in the ignition position.
When I let the key go to the run position, the engine will die immediately.
It acts like the fuel filter is clogged or it stops getting electrical power.
Saturday, August 16th, 2008 AT 10:59 AM
KHLOW2008
MECHANIC
Hi rchamp77,
The ignition switch is bad and has to be replaced.
Monday, August 18th, 2008 AT 4:15 PM
RCHAMP77
MEMBER
Yep, I replaced it and it worked fine.
Thanks.
Monday, August 18th, 2008 AT 11:06 PM
Please
login
or
register
to post a reply.
Related Starter Content
Engine Problems ...
'98 Acura Tl. If I Turn The Ignition Switch To The On Selection. Nothing Happens. The Lights, Radio, Signals, Etc Work But The Car Doesn'...
Asked by
tonio8
1 ANSWER
1998
ACURA TL
GUIDE
Starter
An engine starter is constructed as a high torque, high amperage 12 volt motor fitted with an electrical solenoid and Bendix gear which is used to rotate an engine between...
Can The Harmonic Balancer Be Rebuilt Or Repaired?
1996 Acura 2.6 Tl: What's The Oem Part Number? What's The Oem Brand Name? Can The Harmonic Balancer Be Rebuilt/repaired? Where Can I Get A...
Asked by
andrewlawton
1996
ACURA TL
Engine Removal
I Have The Inline Slant 5 Cylinder 2.5 L Motor For My Tl. Thr Motor Blew And I Will Be Replacing It With Another Used 5 Cylinder Motor. My...
Asked by
dodge504ram
1996
ACURA TL
1996 Acura Tl Oil Drain Plug And Filter
Engine Performance Problem 1996 Acura Tl Two Wheel Drive Automatic 160000 Miles Where Would I Find The Drain Plug And Oil Filter
Asked by
vance10111959
1 ANSWER
1996
ACURA TL
1996 Acura Tl Cant Push The Piston To But The Shows...
Cant Push The Piston To But The Shows On On Rear Break
Asked by
mrbigb420
1996
ACURA TL
VIEW MORE
Starter Replacement
Starter Motor Replacement
Starter Replacement
