2006 Acura RSX Squeaking Noise
2006 ACURA RSX
NSHORT
Noises problem
2006 Acura RSX 4 cyl Automatic 88000 miles
I have a squeaking noise coming from the front right side. This happens when I am going between 20 and 40mph. It does this when I do not have my foot on the gas or brake. When I then press on the brake it stops. It does not happen all the time. I have had my brakes checked and they were fine and ended up getting new struts and the noise is still happening. Any suggestions?
Jul 9, 2009 at 12:57 AM
F4I_GUY
  • 3,302 POSTS
Is the noise going with the wheel?
If so, it is either your brakes or the wheel bearing. My money is on the brakes. Get a second opinion. I bet they just peeked at the outboard pad and said "yup, it's good". You should remove the brake pads and inspect them for noises like these.
Jul 15, 2009 at 1:19 PM
