2006 Acura RSX grinding noise front end
2006 ACURA RSX
32,500 MILES • 4 CYL • 2WD • AUTOMATIC
PRUSSO3
I have a 06 rsx, automatic, it has a grinding/roaring sound from the front end, sounds like both sides, dont think it is the wheel bearings because the noise is in both sides, is there a transmission problem, ie bearing that could be bad, the tires have been rotated and the noise is the same in all weather conditions, snow, rain, or dry weather...
Feb 15, 2010 at 3:00 PM
  • 31,937 POSTS
Hi there,
Have the drive line inspected for any wear, including brakes, rotors, backing plates touching the rotors, wheel bearings as it will be a rotation item causing this noise, start here.
mark (mhpautos)
Feb 15, 2010 at 6:51 PM
