Have an oil consuption issue. Car is smoking in the morning and while driving, one spark plug is fouled. never overheated. used sythetic oil. doesn't seem to smoke while driving when at the low mark on the dipstick. Is this a valve seal job, can it be done with only valve cover being off on this car? compression test done, only dry and all numbers were around 160, equal (manuf recom 138-200 psi). There also seems to be some loss of antifreeze, not sure where its going, no signs of milky oil on the dipstick or around cap, no sweet smell to the exhaust smoke, or burt smell from the radiator. PVC valve was clean, tube has suction.. What is this, cannot be the rings, and if it is, is it possible that its seized and can be fixed by a non conventional method, cheap fix with Miracle oil into the spark plug. Please help.
Oct 31, 2010 at 1:22 AM
