I didn’t buy this prognosis so I disengaged the hot water valve to the heater preventing any hot engine coolant into the heater. The same thing happened. The air conditioner produces very cold air while idling and speeds up to 40 mile per hour then cut out. The fans seem to be working properly I then set the car in park and increased the RPM’s to 2500 up to 4000 RPM’s to simulate highway driving. The electromagnetic clutch on the compressor disengaged causing the blower to produce hot air again. Then I disconnected the compressor low pressure switch coming off the condenser which is attached with the drier viewing window and I connected a jumper wire to bypass the switch. The clutch reengaged but then shut off after a few minutes. I could not locate the relay switch to test it. Can anyone help me? Can this model operate if it has low or too much coolant gas? Could it be electrical?
SPONSORED LINKS
Wednesday, June 23rd, 2010 AT 11:28 PM
