1999 Acura RL replacing hid low beam
1999 ACURA RL
180,000 MILES • 6 CYL • FWD • AUTOMATIC
GIVENS
how do i get pull out the piece needed to replace hid bulb
Jan 14, 2008 at 3:52 PM
JEREMIAH
  • 217 POSTS
you need a screwdriver or bit with a torx end; T-20 i believe. remove the screw from the cover and twist the cover counter-clockwise.twist the bulb's socket,counter clockwise as well.you will see the fastener that holds the bulb.push the fastener in,bring to the side and release.replace the bulb. do not touch any part of the bulb's glass ,the bulb is fastened in one position only AND make sure the car is completely off before you start;30,000 volts is a lot of current.
Jan 21, 2008 at 12:21 AM
