1997 Acura RL odometer and guages
1997 ACURA RL
170,000 MILES • 6 CYL • FWD • AUTOMATIC
CHUNE22
the speed ometer and guages on instrument panel will not work.
Jun 27, 2009 at 10:12 AM
CARLIFE65
  • 200 POSTS
The speedometer gear is located on the output shaft. inspect it for damage. This gear rarely suffers damage because the gear from the speedometer that meshes with it is usually made of a softer material. The speedometer gear on the mainshaft is replacable. its clip hold it in place,or it can be a pressed fit
https://images.2carpros.com/forum/automotive_pictures/420105_00398_speedometer_drive_gear_1.jpg
Oct 13, 2009 at 4:04 AM
